I have brought a 5 inch windows based GPS and am trying to run SkyDemon Inflight on it. I have loaded the SkyDemon Inflight software to the SD card in the GPS via the USB but I get a message on the GPS saying "Please Set Navigation Path". I have set the Navigation Path in the GPS to "\SDMMC\SkyDemon\SkyDemon.exe". I have played around with other settings.
I cannot run ActiveSync as I am only able read the information on the SD card and not alter the settings on the GPS to read anything else.
Anyone else managed to run SkyDemon on a Chinese GPS. If so how did you do it?
Tony
Just saw your post - a bit late I know.
Did you solve your problem ? I loaded on to a 4.3" GPS probably not too different from yours.
Alex
