Plog and Map same screen
FPLS
FPLS
Forum Member (25 reputation)Forum Member (25 reputation)Forum Member (25 reputation)Forum Member (25 reputation)Forum Member (25 reputation)Forum Member (25 reputation)Forum Member (25 reputation)Forum Member (25 reputation)Forum Member (25 reputation)
Posts: 2, Visits: 8
Is there anyway to display the PLOG and the moving map on the same screen on an ipad so we can easily see both whilst flying? Having the ability to see off blocks, landing, takeoff, flight time, on blocks and the PLOG whilst also monitoring the moving map would be a great feature. Also being able to just draw anywhere to quickly write clearances would be a benefit also.
Great app, keep up with the good work!
Felix
marioair
m
Posts: 166, Visits: 1
FPLS - 6/17/2022 3:33:14 PM
Felix
I'd LOVE this option. But think the solution should be related to "documents"
In terms of safety, the time when you spend heads down looking at the ipad should be kept to the minimum. however there are some times when you do need to read or check something. At these times, if you have the map view visible as well, then it would improve safety.
My suggestion would be that the following should be displayed split screen / resizeable:
  • PLOG
  • Any document: AIP entry, approach plates, pooleys
  • Briefing pack
