Viewing elapsed flight time and distance
grahamb - 1/23/2022 10:54:45 AM
Sky Painter - 1/23/2022 10:22:48 AM
grahamb - 1/22/2022 5:37:39 PM
bulldogger - 1/22/2022 7:31:30 AM
I use SkyDemon on a Google Pixel 4a phone and during flights need to see time in the air so far, and distance travelled so far. Is there a way to view that? I've searched the UI but can't find it anywhere.
I guess this is a space/formatting decision, as on a tablet these items are shown in a bar at the top of the plog once under way.
ETE Next/End and Distance Next/End are available in the top bar, but NOT elapsed time so far or distance flown so far.
Actually, I've looked again on an iPhone.
Once the flight has commenced, Flight Time and Distance flown ARE shown at the top of the PLOG. Try it, but if you are not actually moving, you will need to press the 'Log Off Blocks'
Correct. I had overlooked the PLOG.
6332, SD 4.1.2
Too Much Forum (8.7K reputation)Too Much Forum (8.7K reputation)Too Much Forum (8.7K reputation)Too Much Forum (8.7K reputation)Too Much Forum (8.7K reputation)Too Much Forum (8.7K reputation)Too Much Forum (8.7K reputation)Too Much Forum (8.7K reputation)Too Much Forum (8.7K reputation)
Posts: 595, Visits: 29K
6332, SD 4.1.2
BJS
B
Too Much Forum (569 reputation)Too Much Forum (569 reputation)Too Much Forum (569 reputation)Too Much Forum (569 reputation)Too Much Forum (569 reputation)Too Much Forum (569 reputation)Too Much Forum (569 reputation)Too Much Forum (569 reputation)Too Much Forum (569 reputation)
Posts: 47, Visits: 149
In usual installations flight time is most often a function of your transponder. Why do you want travelled distance instead of flight time?
To see 'time in the air so far' I suggest that you:
1. Use your device's built-in stopwatch running in the background;
2. Use the aircraft's stopwatch, if it has one, or;
3. Use your wristwatch, if you have one (there are many aviation friendly wristwatches available at a reasonable price);
4. Use the Ruler Function (see below).
For 'distance travelled so far' I suggest that you:
1. Use the Ruler Function, which will provide Track, Time, Groundspeed and Fuel Consumption, or;
2. Divide Groundspeed by Time Elapsed.
Hope that helps.
6332, SD 4.1.2
bulldogger
b
Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)
Posts: 3, Visits: 0
