Flight Plans - prepare for not immediate filing
When recalling a saved flightplan, would you expect it to be updated to reflect any changes to the route you've made in the meantime? Which fields should be updated if so? How would SkyDemon know that the flightplan necessarily represents the route loaded at the time the flightplan was loaded?
Ian Hibbert
Ian Hibbert
Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)
Posts: 38, Visits: 297
A key change will probably be the expected off-block time and potentially routing information, this may change for a number of reasons and will become firmer as the flight draws near. It would be good if the plan picked up changes automatically when referencing the revised route, minor changes may be to ancilliary data i.e. someone has found a strobe or liferaft they're now bringing along or have hired at the last minute, captains name & contact may change etc
Ian
Given that most of that information is automatically filled in my SkyDemon when the flightplan is generated, I'm struggling to understand the big benefit in being able to save and restore a prepared flightplan. If there's an underlying problem that could be solved, I'd rather solve that.
Ian Hibbert
Ian Hibbert
OK, yes perhaps I'm not fully au fait with just how much is auto generated, next time around I'll see if I can pull out specifics that would add value. It may in fact be fine as it is....
Ian
milansmid
milansmid
Posts: 68, Visits: 565
Tim,
I am coming back after sime time and see this feature attracted some interest from the others... Smile
My points were the following:
1) I usually do not change the route - just the times. And as I always re-write the times calculated by SD (round up to 5 min and add some margin to allow for little deviations) I am basically re-writing a big part of the flight plan.
2) I also have to fill in every time some of the aircraft supplementary specifications like emergency equipment and my phone number in the remarks...
What might be the solution?
ad 1) Let the flight plan to be saved within SkyDemon flightplanning package (and/or to customer area accessible from the web page) - I can imagine three buttons there: Submit, Cancel, Save (the Save button would not save it on the disk but would close the flight plan dialog which would then be saved together with other data within the flightplanning package) - for later editing and filing.
ad 2) In the aircraft section, add a tab with the supplementary information. This info would then be inserted directly into the flight plan like the other data (immatriculation, type...).
How about that?
Milan
Edited 7/21/2011 1:19:36 PM by milansmid
