Checklist with speak
KimW
K
Posts: 59, Visits: 0
I would like to see Skydemon supporting airplane checklists, with the option to have SD call out the items, with the current speak capabilities. This may also be linked to the alarm feature to enable checklist pop-up for recurring items during enroute.
What do you think? Would it be of value to others?
David Johnstone
David Johnstone
Too Much Forum (960 reputation)Too Much Forum (960 reputation)Too Much Forum (960 reputation)Too Much Forum (960 reputation)Too Much Forum (960 reputation)Too Much Forum (960 reputation)Too Much Forum (960 reputation)Too Much Forum (960 reputation)Too Much Forum (960 reputation)
Posts: 16, Visits: 602
Personally I prefer to do the check lists from memory. One of my syndicate relies on SD to remind him to switch tanks every 30 minutes. One day he flew without SD and returned with one tank almost empty and the other full.
Moral learn your checks, it was all the rage 40 years ago when I learnt to fly.
PaulSS
P
Posts: 99, Visits: 3.2K
It's a navigation package, not a checklist app, performance calculator or coffee maker. If you're flying a machine that warrants an electronic checklist then Boeing or Airbus would have given you proper one with little green ticks when you've been a good person. If there's nobody next to you to read out the checklist then you don't need one.
BJS
B
Posts: 47, Visits: 149
Looks like SD is not supporting the speak text function?
@Development, please enable this system function.
Ridgeskimmer
R
Too Much Forum (679 reputation)Too Much Forum (679 reputation)Too Much Forum (679 reputation)Too Much Forum (679 reputation)Too Much Forum (679 reputation)Too Much Forum (679 reputation)Too Much Forum (679 reputation)Too Much Forum (679 reputation)Too Much Forum (679 reputation)
Posts: 20, Visits: 7
Checklists from memory??!!!....scary!
Great audio checklist here with voice recognition...... https://www.miracheck.com/
You can make up your own or use ones already created. I use one in my Jodel!! Works a treat
Cheers
Ridgeskimmer
R
Ridgeskimmer - 11/11/2021 9:02:42 PM
Cheers
Here it is sat alongside Skydemon on my ipad
ROGER62
R
Junior Member (20 reputation)Junior Member (20 reputation)Junior Member (20 reputation)Junior Member (20 reputation)Junior Member (20 reputation)Junior Member (20 reputation)Junior Member (20 reputation)Junior Member (20 reputation)Junior Member (20 reputation)
Posts: 2, Visits: 0
Ridgeskimmer - 11/11/2021 9:16:23 PM
Cheers
ROGER62
R
Posts: 2, Visits: 0
Cheers
Hello, but this function here of checklist is available only on ipad ? On android or PC i don't find it.
Andrew
A
Too Much Forum (470 reputation)Too Much Forum (470 reputation)Too Much Forum (470 reputation)Too Much Forum (470 reputation)Too Much Forum (470 reputation)Too Much Forum (470 reputation)Too Much Forum (470 reputation)Too Much Forum (470 reputation)Too Much Forum (470 reputation)
Posts: 28, Visits: 88
ROGER62 - 12/22/2021 5:46:24 PM
Cheers
It doesn't exist in SD - looks like Ridgeskimmer is using the Ipad split screen / overlay feature to overlay the checklists created in . https://www.miracheck.com/
Ridgeskimmer
R
Correct
