No audible inflight alerts with SkyEcho2
Happy Wanderer
H
Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)
Posts: 3, Visits: 0
Hi folks, seems to be a regular issue this reading various forums...!
I have a Lenovo TAB4 8 Plus tablet (generally excellent) with Android 8.1.0 OS linked via wi-fi to a newly-purchased SkyEcho 2 tranceiver. As I have the older-version Bose A20 headphones, I have to use a 3.5mm audio jack to link headphones with tablet - Bluetooth only works with a phone. I've gone through all the various SD settings top to bottom (Navigation Settings > Produce Speech for Warnings [enabled] Produce Sounds for Warnings [disabled]). In SD simulator mode on the ground with the tablet connected to the office/home wi-fi, I can see traffic/hazard alerts on the tablet screen and hear the same through my headphones; in-flight, with the tablet connected to SkyEcho, I can see the alerts, but hear absolutely nothing.
Anyone got any ideas or had a similar problem? If it makes a difference, I've disabled the 'Auto-off' function in the A20 Control Module which basically means the ANC doesn't now turn off during periods of inactivity.
TIA.
Posts: 659, Visits: 32K
Happy Wanderer - 5/21/2021 4:27:01 PM
TIA.
Stupid question perhaps, but have you checked the Bluetooth volume on the headset?
Happy Wanderer
H
Posts: 3, Visits: 0
grahamb - 5/21/2021 5:55:05 PM
TIA.
Er, and it might be a stupid answer, but I'm assuming it won't be a Bluetooth connection as the headphones and tablet are wired using a 3.5mm auxillary input cable. The tablet volume buttons will control the alerts volume.
Thanks.
Happy Wanderer - 5/21/2021 7:49:19 PM
TIA.
Thanks.
Sorry, yes, I couldn’t remember whether the BT volume buttons controlled the aux volume as well. My A20’s were phone-only BT until I went to the US a couple of years ago and bought the later control box and leads.
