Possible Defect: correct calculation of MSA for legs to account for fly/over/fly by and starting and...
Possible Defect: correct calculation of MSA for legs to account for...
Posts: 8.2K, Visits: 9.6K
Thank you. Yes, you have highlighted a bug in our code where certain junctions of legs could fail to correctly pick up obstructions in the arc forming the junction. The next version of SkyDemon will contain a fix to this.
lhe
lhe
Posts: 154, Visits: 445
Tim Dawson - 9/10/2020 9:49:50 AM
That great. Thank you.
Could you also fix the MSA computation so that obstacles in a semicircle before the starting point of the route is considered in the MSA computations? Just as obstacles in a semicircle after the end point of the route are considered.
When departing from an airport you can't always depart directly in the direction of the route. Runway in use, noise-sensitive areas and/or ATC procedures can mean that you have to fly for some time in the area "before" the route and then obstacles before the route are relevant.
Yes, we will do that, but just for the very first leg in your journey.
Edited 9/10/2020 1:12:35 PM by Tim Dawson
