Ability to set default Flight Mode in settings
Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)
Posts: 608, Visits: 29K
I fly IFR OCAS quite regularly so want the VFR chart displayed by default, and I find it irritating that I have to remember to change flight mode from ‘ VFR’ two ‘Mixed’ each time I create a new route. Forgetting to do so means I may miss some relevant NOTAM.
Any chance that a preferred mode could be created in Setup > Planning options?
marioair
m
Posts: 158, Visits: 1
That’s a massive issue isn’t it?
pilot-byom
p
Posts: 323, Visits: 388
I doubt a 'default' philosophy covers the most mission profiles.
How about a mandatory pop-up instead, asking will you stay your last selection?
pilot-byom - 8/31/2020 6:37:13 AM
The problem with mandatory pop-ups is that they invariably annoy most people and then there is then a general clamour to remove them.
I think a default option does cover most options. Most of my SkyDemon-using acquaintances are pure VFR flyers, the rest being mostly VFR with the occasional non-airways IFR.
rg
rg
Posts: 109, Visits: 1.9K
Couldn’t agree with this more. I would prefer to use mixed as my default route type.
rg
rg
This would be an essential feature. It’s verymannoying that with IFR features enabled. I don’t see IFR NOTAMs unless I remember to change the route to mixed mode (which I often forget).
marioair
m
I have some other significant (safety of life) issues I’m going to raise as separate threads. But this issue is in the same class I’d say.
marioair
m
I think two things are needed.
Option to set default flight mode
Reminder in NOTAMS and PLOG what mode was used
DavidC
DavidC
Posts: 23, Visits: 30
I think this is an important feature - I have been caught out by not seeing an IFR NOTAM recently.
Although numerically the majority of SkyDemon customers are VFR only, the number of flights/flying hours is probably skewed by instructors/instructional flights where the instructor is more likely to be IRR rated and also needs to be more aware of IFR NOTAMS.
I default global setting would suffice as a minimum. The current mode being displayed at the top of the NOTAM page would help enormously.
--- CPL/IR/FI based in South of England
marioair
m
@Tim is this something you’d consider?
