Alastair Mutch
Visits: 0
I modified the earlier Airconnect (one with a pin code). This was done using the user interface described for the Microchip WiFly module used in these earlier units. I turned off the detection of LF (0xA) and set it to instead send out a Wifi packet when there was a gap of 100ms or more in the datastream to force it to send the GPS data in fewer, bigger chunks. This seemed to work OK on the ground - capturing the input data to Airconnect from flarm and also the output data on wifi and comparing the two showed no differences whereas with the original set-up it had occasional errors. (The newer Airconnect unit without a pin code had errors every few seconds. This uses a design from a German company In-Circuit and is not configurable afaik ).
Our gliding airfield has been flooded for a while and so I only managed to fly with the modified Airconnect once. Whilst it was 100% reliable on the ground. it still caused a Skydemon error in the air during the flight - when I was close to some busy airspace, close to patchy cloud and a bit stressed. This was with a Powerflarm Core. I haven't tried it again.
I gave up at that point and bought some serial to Wifi adapters from ebay and used them to replace the Airconnects on both of the aircraft I fly with Skydemon - a Falke motorglider and an AA5. I tested the adaptor at home in the same way as the Airconnect units and didn't see any data loss or corruption. I also tried a second different Taiwanese adaptor and that worked OK too.
When I tried it last week in the AA5 with a Powerflarm (FlarmBat) it was perfect for the whole 1 hour flight. We had two android tablets running Skydemon connected to it as my passenger also used his. Both worked perfectly and showed all of the traffic as expected. It worked 100% reliably on the ground when tested - no data corruption. .
The adaptor I used is this one: (I did try another adaptor from Taiwan as well and that worked fine too)
It’s simple enough to program it to emulate the Airconnect protocol – 192.168.1.1 and Port 2000. I set it to detect a gap in the serial data of greater than 100ms and send a Wifi packet out. I used a 9 way D-Type to rj15 adapter and then a bit of rj15-rj15 cable (6p6c) was quick and easy to knock up. It only needs +12V, 0V, TXdata and Rxdata connected.
A suitable adaptor plug is here:
I've chased Airconnect a few times but they don't have a fix for their units. Having said that several people seem to have them working without any issues - even on Powerflarms. Things tend to go wrong when I go near them I guess. Life it just too short to sort out other people's mistakes though.
Alastair
ken@blackman.co.uk
Visits: 131
Hi, Following Alastair's very kind and patient advice I changed my very unreliable Airconnect for the WA-232E Alistair mentioned. I have a PowerFlarm portable connected to SD on an iPad via the wifi adapter WA-232E. I haven't done a lot of flying with it yet but so far it has proved 100% reliable. It has the added advantage that you can have up to 4 devices connected to the WA-232E, so I have a the PowerFlarm connected to my iPad and also to my iPhone which I use the full screen traffic radar falicity on SD for mobiles. Another advantage is that the WA-232E can be battery powered so I don't have to start the engine before configuring my PowerFlarm portable and SD for the flight.
On a related matter mode C/S traffic is no longer displayed on my SD although it is still shown on the screen of my PowerFlarm portable. This seemed to have stopped around the time of the last upgrade of SD. I have double checked all the settings on SD and my PowerFlarm to ensure that will all allow the display of mode C/S traffic on SD (again this was working late last year). Using a telnet session I have collected logs of the sentences coming out of my PowerFlarm data port and sent them to SD and Flarm, but unfortunately no fix yet.
I was just wondering if anyone else has seen this problem? I am aware of one other pilot who has experienced the same problem.
Posts: 7.8K,
Visits: 8.4K
Ken, there was no bearingless traffic information in the data you sent us.
Is it possible Flarm have stopped sending bearingless information on the datastream or made it optional?
Alastair Mutch
Visits: 0
+xKen, there was no bearingless traffic information in the data you sent us.
Is it possible Flarm have stopped sending bearingless information on the datastream or made it optional? I just checked mine yesterday as a C152 flew past my house with only mode-C and got both the traffic message and the circle appearing on SD. Very strange.
Alastair
Thomas
Visits: 136
+xI modified the earlier Airconnect (one with a pin code). This was done using the user interface described for the Microchip WiFly module used in these earlier units. I turned off the detection of LF (0xA) and set it to instead send out a Wifi packet when there was a gap of 100ms or more in the datastream to force it to send the GPS data in fewer, bigger chunks. This seemed to work OK on the ground - capturing the input data to Airconnect from flarm and also the output data on wifi and comparing the two showed no differences whereas with the original set-up it had occasional errors. (The newer Airconnect unit without a pin code had errors every few seconds. This uses a design from a German company In-Circuit and is not configurable afaik ).
Alastair
Hello Alastair, thank you very much for your Description. I have ordered this Adapter and will report when its installed. Thomas
ken@blackman.co.uk
Visits: 131
Is it possible Flarm have stopped sending bearingless information on the datastream or made it optional? Hi Tim, following further patient and kind help from Alastair I have managed to get Mode C/S traffic displayed on my SD. It turned out that you were correct, my Powerflarm portable had stopped sending bearingless information on the datastream. Changing the settings on my PF from the control knob on the front had no effect, Alastair showed me how to reconfig my PF by loading a new config file via a SD card.
Many thanks for your help.
Ken
Peer
Visits: 391
+x+xKen, there was no bearingless traffic information in the data you sent us.
Ken
Hi Ken, which firmware is on your PF Portable?
ken@blackman.co.uk
Visits: 131
+x+x+xKen, there was no bearingless traffic information in the data you sent us.
Ken
Hi Peer
Apologies for the delay in replying. My PF is on version 6.82
Ken
Europa XS
Visits: 215
Alastair
Dear Alastair, I have been struggling with the same data transfer problems with AirConnect (with pin) for a long time. Have actually given up. I am interested again through your research. I bought a serial / WIFI connector that is largely freely programmable. But I'm not a specialist. Can you give me some tips or even better instructions? I'm grateful for any support. Thank you very much Herbert
Alastair Mutch
Visits: 0
+x+xI modified the earlier Airconnect (one with a pin code). This was done using the user interface described for the Microchip WiFly module used in these earlier units. I turned off the detection of LF (0xA) and set it to instead send out a Wifi packet when there was a gap of 100ms or more in the datastream to force it to send the GPS data in fewer, bigger chunks. This seemed to work OK on the ground - capturing the input data to Airconnect from flarm and also the output data on wifi and comparing the two showed no differences whereas with the original set-up it had occasional errors. (The newer Airconnect unit without a pin code had errors every few seconds. This uses a design from a German company In-Circuit and is not configurable afaik ).
Alastair
Dear Herbert, The instructions are dependant on the type of Wifi unit you have bought. If it is the WA-232F that I mentioned above then I can give you a link to some screen dumps of how to set it up easily enough. Alternatively you can send me your unit and I'll set it up and knock up a cable for you. Best PM me rather than clutter up Tim's nice forum. aim (at) scottishglidingcentre.com will get through.
Alastair.
