dragging route on mobile device
woodysr2
woodysr2
Too Much Forum (825 reputation)Too Much Forum (825 reputation)Too Much Forum (825 reputation)Too Much Forum (825 reputation)Too Much Forum (825 reputation)Too Much Forum (825 reputation)Too Much Forum (825 reputation)Too Much Forum (825 reputation)Too Much Forum (825 reputation)
Posts: 7, Visits: 38
Hi Guy's finally got the bugs out of my no name chinese satnav and it is now visible in daylight(I think because north of the border the sun has been hiding for the last couple of weeks)
I was sent a RAR. file from the company "brush software 705" which did the trick re installed the control panel
But I am still having trouble trying to drag a route on the mobile device ons plotted is there a problem with the sync on my device as I paid for the software allowing planning on the unit and this function is really helpfull for getting around airspace etc.
Any help appreciated
cheers
William
always willing to learn even if it is slowly LOL
Runways
Runways
Too Much Forum (38K reputation)Too Much Forum (38K reputation)Too Much Forum (38K reputation)Too Much Forum (38K reputation)Too Much Forum (38K reputation)Too Much Forum (38K reputation)Too Much Forum (38K reputation)Too Much Forum (38K reputation)Too Much Forum (38K reputation)
Posts: 309, Visits: 1.6K
A brilliant idea in SD Planning. For some reason not an option on mobile and probably not too practicable in flight, even on 7 inch screens.
Very Newbytheway
DurhamTeaseAirport
woodysr2
woodysr2
It was not for inflight use but if you are out in the islands of Scotland and as usual the weather or some other unforseen circumstance rears its ugly then it would make life alot easier being able to drag the route as you wantedmakes planning a route quick and simple
pink leader
pink leader
Posts: 518, Visits: 2K
You can do the equivalent of "drag & insert" a waypoint. Just tap & hold on the desired waypoint and an options box will appear  .. one of these will be allow you to "insert before" next waypoint. You can do this as often as you like to change the route.
D
