Delete SD data from Android ?
Easy Cruising
Easy Cruising
Posts: 50, Visits: 39
I believe this has been treated before on the forum but I couldn't find the topic by searching in the search box. Anyway, my SD seems to have filled the device storage, probably because I loaded too many AIP documents. I would like to clear some of these out without removing SD,  but don't find where the data is stored. Can anyone enlighten me or point to an existing post where it's discussed. Would be appreciated.
Easy Cruising
Easy Cruising
Easy Cruising - 7/15/2019 12:56:39 PM
To answer my own question I went to Airfields-->Tools-->Clear Document Cache, then loaded all the desired AIP's again individually. Free space increased a lot after that.
