Visits: 434
This is a two part request:
1) Aircraft Profile - add ability to set different fuel values for VFR and IFR for each aircraft profile. An example for an AW109 helicopter would be say: VFR Start/Taxi 10kg Contingency 5% Final Reserve 80kg
IFR Start/Taxi 20kg Contingency 10% Final Reserve 110kg
2) Route - add ability to set each sector to either VFR or IFR e.g. A route with multiple sectors (Land Here) Sector 1 - Biggin Hill to Battersea VFR Sector 2 - Battersea to Oxford IFR And so on
At the moment, the workaround is to create 2 different aircraft profiles, one with VFR fuel and the other for IFR. However, you can only specify one profile per route. If you decide to change the profile for a different sector, you lose any W&B figures you may have entered early on.
Regards Pete
