Visits: 128
I have created several waypoints in SD PC, which I can export as a GPX. How do I share them with other SD users using Android? There is no 'import' function in Android. If you try to load as a flightplan it says 'unreadable' or similar. A can share a flightplan that uses the waypoints, but the waypoints aren't included. For those that don't have a PC, what's the easiest way to do this? I can just pass on the waypoint name and GPS co-ordinates for the other group members to create, so it's OK, but, am I missing something? Regards
