Defining a new airfield possible?
Cessna
Cessna
Posts: 9, Visits: 50
Sorry if this obvious but I can’t work it out. I’ve been using SD for years from a strip which is on the system as a proper airfield. The aircraft has now moved across to a new strip which is not on SD. I have added it as a new user waypoint which means I can plan routes without issue.
However when SD is in navigation mode and logging and I land the aircraft, it logs the fact that I have landed at the old strip. The distance between strips is probably 1.5 miles, so I can see why SD might think I’ve landed on a runway associated with the old strip.
Is there a way to define a new airfield?
Martin Bech
Martin Bech
Posts: 152, Visits: 352
Cessna - 12/9/2017 6:15:00 PM
Yes, in the Windows version. After creating the airfield it can be moved to Ipad.
Cessna
Cessna
Thank you. Done and seems to be working fine.
Cessna
Cessna
