Track radial into ILS
ericferret
e
Posts: 11, Visits: 0
Maybe I just haven't worked out how to do it. If I use "Direct To" then adjust course to pick up the extended centre line, then on final approach the HSI switches to ILS mode. So far so good. But if I use the Track Radial function to intercept the centre line I cannot then get it to change to ILS mode. Using "Direct To" doesn't seem cancel the Track Radial function.
ericferret - 11/19/2017 12:40:42 AM
You must first cancel Track Radial by tapping on the Position Report block just below the Instrument Panel. The HSI should then work as expected.
26200.7840, SD 4.2.3
ericferret
e
Sky Painter - 11/20/2017 6:13:12 PM
Thanks Mike, just had a chance to try it out and it works.
