SkyDemon Navigation
Connectivity with Pilotaware no longer working
Peter@gclac.com
P
Peter@gclac.com
posted 8/25/2017 11:00:36 AM
P
Visits: 29
SD Version 3.8.2.24057.
I have been using Pilot aware quite nicely using FLARM connectivity and key set to 6000. I now note that SD has a new connectivity option 'Piloraware'. When I select either Pilotaware or the old FLARM way, I get SD error ' No data has been received from your GPS for some time and connection therefore lost...'.
My Pilotaware system is working fine stand alone with no errors. It's just SD no longer will connect . Any ideas - is this a known issue?
Peter
leemoore1966
leemoore1966
posted 8/26/2017 9:38:57 AM
Visits: 46
Hi Peter,
You must be running PilotAware version 20170721 or later to use this connection method
Thx
Lee
