Mass and Ballance
Hans Nielsen
Hans Nielsen
Too Much Forum (556 reputation)Too Much Forum (556 reputation)Too Much Forum (556 reputation)Too Much Forum (556 reputation)Too Much Forum (556 reputation)Too Much Forum (556 reputation)Too Much Forum (556 reputation)Too Much Forum (556 reputation)Too Much Forum (556 reputation)
Posts: 4, Visits: 8
Hi regarding Units, can you make it so that when making a new profile for a aircraft, the posibillity to use other then master units set in the main programe ? like when making a Edit in Fuel I have a lot of options to change to Litter ore USG ore... I'll like the same option under Speeds to flip flop to KMH ore KTS ore MPH, ore under Weight and Ballance to use lb ore kg or ???
L‌ike when flying one aricraft i know that it is in KG / CM and in another it is in USG / LB without having to re do the main settings
B‌est regards
H‌ans Nielsen
