Aircraft W&B keeps on changing itself
N34X
N
Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)
Posts: 2, Visits: 0
I'm trying to configure a first aircraft.
‌A C150 with following envelope:
‌80.01,527.00, 80.01,580.598, 83.566,726.4, 95.25,726.4, 95.25,527.00
‌Pairs in cm and kg's.
‌Correct envelope seems valid at first, but after closing the window the aircraft "Is out of envelope" and after rechecking the values were changed:
8001,00,52700,0, 8001,00,58099,0, 8357,00,72600,0, 9525,00,72600,0, 9525,00,52700,0
‌What is wrong with my configuration, and why is the system trying to force comma's between the coordinate pairs and also as decimal?
‌Thanks!
T67M
T67M
Posts: 206, Visits: 3.2K
N34X - 2/3/2017 8:40:23 PM
‌Thanks!
I can't find the reference, but I think this has been reported before where the locale of the computer uses the comma for a decimal point. Can you try changing your operating system settings to one where the dot is used for decimal point (e.g. United Kingdom), give it a try again and report back?
Page 30 of the Instruction Manual may help you.
26200.7840, SD 4.2.3
N34X
N
Posts: 2, Visits: 0
Solved by copy-pasting the data in on iPad. On the webbased platform on a Mac I cannot seem to make it work, even by using the different format as stated in the manual.
