Partial complete PLOG
FF - 9/19/2016 12:31:47 PM
T67M - 9/15/2016 4:27:12 PM
FF - 9/15/2016 3:29:58 PM
Tim Dawson - 9/9/2016 3:42:15 PM
I don't think so; the set speed is true or indicated airspeed and your actual speed over the ground will of course be different.
if I do not select "perform wind calculation" in "settings" I do not have any information about GS and TIME in the pilot log (computer)!
For me is very important to have the data in zero wind conditions because I can program the flight the day before.
Surely this is expected - if you turn off the wind calculations, SkyDemon cannot calculate either the ground speed or the time as these are affected by the wind.
If you want a "zero wind" PLog, go into the "Weather" pane, select "Weather Tools", then "Set wind conditions for flight" to "0/0" instead of "Auto". This can be done for the entire flight, or leg by leg if you prefer.
How can I set 0 wind conditions on the computer?
I don't think T67M could explain it any simpler or in any more detail than he already has:-
If you want a "zero wind" Plog, go into the "Weather" pane, select "Weather Tools", then "Set wind conditions for flight" to "0/0" instead of "Auto". This can be done for the entire flight, or leg by leg if you prefer.
6575, SD 4.2.2
FF
F
Posts: 20, Visits: 3
Sky Painter - 9/19/2016 12:50:41 PM
Excuse me, where is the weather panel on the computer software? I can see it only on ipad software!
FF - 9/19/2016 1:54:14 PM
6575, SD 4.2.2
FF
F
Sky Painter - 9/19/2016 3:11:28 PM
