Peter Robertson
Visits: 147
Hi Guys,
As I have said before elsewhere, with the minimal info we get for bearing less targets, clear indication of threat level (colour changing icons of whatever style - I can live with rings) is essential, as is relative altitude to 'direct' visual search and prompt potential action to maintain or increase separation. Anything else (e.g. Reg) is a bonus which just might help in locating the threat but not essential.
I'm sure the two of you will be able to agree the best way forward. We are all very grateful and are counting on you both.
Best regards
Peter
Posts: 8.3K,
Visits: 10K
Lee, the sample protocol data you gave seemed to be absent of any identifier. As somebody was asking for identifier, I asked for an example of real-world protocol data for bearingless target with identifier so that I could make sure it didn't mess anything up in SkyDemon. This was as a follow-up to your statement that you had explicitly disabled the transmission of identifiers to SkyDemon for bearingless targets.
leemoore1966
Visits: 46
+xLee, the sample protocol data you gave seemed to be absent of any identifier. As somebody was asking for identifier, I asked for an example of real-world protocol data for bearingless target with identifier so that I could make sure it didn't mess anything up in SkyDemon. This was as a follow-up to your statement that you had explicitly disabled the transmission of identifiers to SkyDemon for bearingless targets. Hi Tim OK, understand. Let me dig out some examples which contain the identifier, although you can pretty much fake these up by adding in the ICAO and Reg into the correct field, eg, if the identifier is " 40526F!G-PAWZ" then something like ... $PFLAA,1,4500,,2841,1,40526F!G-PAWZ,,,,,0*48 (NB, the Checksum will be incorrect for this)
Thx Lee
Posts: 8.3K,
Visits: 10K
Thanks Lee. If you can dig up some concrete examples from a log then I will have a play with this on Friday.
Paul_Sengupta
Visits: 218
One thing I would ask, which I've mentioned on Flyer, PilotAware, at AeroExpo but now on here (!), would it be possible to have the option of the flight ID/relative altitude appearing in a white box, maybe with a black border? The contrast of the existing fields isn't good with a background map and makes them very difficult to read. Having them in a white box which blanks out of the background map would be better, especially for the bearingless altitude which appears in a seemingly random place around the ring.
Having these things stand out would make it instantly readable rather than having to stare and squint.
Ta!
leemoore1966
Visits: 46
+xDue to an almost incident yesterday I like to push a reminder into this circle -> even if you use gadgets like Pilotaware while being VMC, LOOK OUTSIDE !!! A fellow foreign pilot yesterday approached our home field and yelled over the radio at the training machine drilling circuits, complaining why it had no signal on his little traffic box. Yes, we did have a serious talk to the pilot after landing. Hi Shifu it had no signal on his little traffic box Can you tell me what 'little traffic box' your fellow pilot was using ? I feel it is incumbent upon the suppliers of this type of technology to stress the need for good airmanship. When accepting the license agreement with PilotAware there is a huge banner explaining the use policies. I am very interested to know the circumstances of use. I like to push a reminder into this circle I am not sure what you mean here, this is in the forefront of my mind, in fact, here is a posting I made recently on this very subject http://forums.flyer.co.uk/viewtopic.php?t=101106&start=45#p1474702If you think there is more we could do, I would be interested in your feedback, but may be better placed on the PilotAware forum rather than cluttering the SkyDemon forum Thx Lee
leemoore1966
Visits: 46
+xThanks Lee. If you can dig up some concrete examples from a log then I will have a play with this on Friday. Hi Tim, OK, I have generated 2 logs mode_cs_id.trkThis contains the ID field, I double checked, and in the NAV display you ALWAYS have a grey/white ring, irrespective of the threat level value mode_cs_no_id.trkThis does not contain the ID field, and the rings are red/yellow/green accordingly based upon the threat level. In the trk files you will see some extra NMEA style messages for instance $PAWRT these are not sent to the navigation device, its only in the logging format, this is to describe the received data for the ID, using a boolean of the form $PAWRT,<ID>,Mode-A,Mode-C,Mode-S,ADS-B,P3I,FLARM,<checksum> So for your usage I would seggest 'grepping' out the PFLAA messages Please let me know if you need more info Thx Lee
leemoore1966
Visits: 46
Hi Shifu He told us it would be capable of receiving Mode A/C/S, ADS-B, FLARM and P3i. Could you PM me his contact details, I know of no such technology which is capable of receiving all of these formats. PilotAware in conjunction with FlarmMouse is capable of all these (except Mode-A), but that version is not yet released! Would you support an initiative to feed all the loose ends in protocols to one worldwide standard Yes we would support this, are you referring to an RF standard, or a Traffic Format standard ? There is disparity in both, for example RF - US (1090Mhz, 978Mhz, 915Mhz-FHSS), Europe (1090Mhz, 868Mhz) Traffic - GDL90(open), GDL39(closed), FlarmDataport(open) I think an RF standard will be near impossible to standardise - especially as FLARM Encrypt their data, but a common Traffic format would be an acheivable goal. Thx Lee
Paul_Sengupta
Visits: 218
Posts: 8.3K,
Visits: 10K
Thanks, Lee. I can confirm that when SkyDemon saw the ! that I specified be used as a delimited for our protocol extension to feed callsigns through, it reset the "threat level" to unspecified because that ! also triggers our own internal collision detection code. Since that code doesn't run for bearingless targets, I have modified the Flarm parser to not reset the "threat level" you pass when it's a bearingless target. Incidentally, now that you are (presumably) running your own on-device collision detection code (to power your audible alerts) do you also send Flarm protocol alerts through too, and a meaningful "threat level" for positioned targets?
I have also modified the text rendering so it's the same size, and uses the same black-on-yellow glow, as the positioned targets. The position of the text remains unchanged, which is to draw it on the outside of the "circle of probability" in the direction that you are currently travelling.
Paul, we would consider adding a white background behind the traffic details if enough people asked, but my feeling is that it would obscure much more of the map if we did that. When it comes to rendering other traffic we are very mindful of what things will be like when everybody is broadcasting their location (what we ultimately want). I think to have such a solid background, when we get to that wonderful stage, would not be ideal.
