active leg
damirf
damirf
Too Much Forum (648 reputation)Too Much Forum (648 reputation)Too Much Forum (648 reputation)Too Much Forum (648 reputation)Too Much Forum (648 reputation)Too Much Forum (648 reputation)Too Much Forum (648 reputation)Too Much Forum (648 reputation)Too Much Forum (648 reputation)
Posts: 6, Visits: 3
In skydemon onething bothers me. When I flying  to a specific airportand back, because the legs in one direction and back are very close, skydemon very often toggles between the active leg and legback, especially if I go off route. Isit possible to prevent this, or to choose which leg is active, so skydemon cannot switched to the second leg.
Too Much Forum (68K reputation)Too Much Forum (68K reputation)Too Much Forum (68K reputation)Too Much Forum (68K reputation)Too Much Forum (68K reputation)Too Much Forum (68K reputation)Too Much Forum (68K reputation)Too Much Forum (68K reputation)Too Much Forum (68K reputation)
There is a workaround available: tap on your destination airport and choose "Land Here". That splits the route into two sub-routes, each with a single leg. SD doesn't switch between routes, only between legs. When you fly back, simply tap on the return route to activate it. It will stay active.
Greetings, -- Chris.
T67M
T67M
Posts: 206, Visits: 3.2K
Another option is to use the same route and the "reverse" function to get back home.
damirf
damirf
Posts: 6, Visits: 3
THX
jfw
jfw
Posts: 134, Visits: 485
I already highlighted that issue in an older post: http://forums.skydemon.aero/Topic17302.aspx
Br,
Jf
