Feature suggestions
johnor999
johnor999
Too Much Forum (289 reputation)Too Much Forum (289 reputation)Too Much Forum (289 reputation)Too Much Forum (289 reputation)Too Much Forum (289 reputation)Too Much Forum (289 reputation)Too Much Forum (289 reputation)Too Much Forum (289 reputation)Too Much Forum (289 reputation)
Posts: 2, Visits: 14
First off, I'd like to thank you for a very good flight planning tool!
I do have some sugestions:
1. Fields for enroute temperatures in the OFP and ISA deviation. (next to each leg)
2. Fields for individual fuel and time per leg and accumulated fuel and time per leg in the OFP.
3. Wind correction angle in the OFP.
4. True heading in the OFP.
5. Support for more than one alternate would be helpful for IFR purposes, for small multi engine piston aircraft, you will be required to have a take-off alternate if the visibility at the departure airport is bad enough.
6. Support for multiple climb and descent profiles, like with cruise.
7. An option to display MSA in the chart would be helpful for IFR purposes.
I know that SkyDemon is a VFR flight planner, but by making it just as good for GA IFR, I think you would gain some customers that would otherwise turn to other products. (which will remain anonymous here)
Edit: sorry, I accidentally posted this in the wrong forum section. I thought I had posted it in the Suggestions section, but obviously messed up. Feel free to move the topic.
Best Regards
Johan Nordqvist
Edited 4/2/2016 12:02:48 PM by johnor999
Many of your suggestions are already in the product. Have you read the documentation?
johnor999
johnor999
I can't find anything in the user manual regarding temperature enroute, wind correction angle, true heading, any info on how to define more than one alternate, info regarding how to define more than one climb/descent profile and nothing on ISA deviation?
Please tell me where in the manual I can find info on these features if they are indeed implemented already.
Best Regards
Johan Nordqvist
