Visits: 119
Would a feature to calculate the rate of descent at a random point be possible? For example, if you need to be at a 2000' VRP from FL100 - what is the correct descent rate...? Suggest pressing a map point allows the user to enter desired altitude and a known IAS is then used to give Vertical Descent Rate.
