Windows 7
Sussex Flyer
Sussex Flyer
Posts: 22, Visits: 95
Each time I open Sky Angel Version 0.9.8.16605 and plot a route in Windows 7 for the first time after a PC start-up , the Sky Angel crashes. Re-starting Sky Angel solves the problem.
Sussex Flyer
Edited 11/18/2009 6:02:20 PM by Sussex Flyer
Posts: 8.1K, Visits: 9.3K
What about with the latest release? 0.9.8 is not current and a bug relating to 64-bit Windows (Vista and 7) has been fixed since that build, I believe.
Sussex Flyer
Sussex Flyer
Now using version 0.9.10.20643 and so far the problem has disappeared.
Sussex Flyer
Steve
Steve
Posts: 55, Visits: 123
I'm using version 0.9.12.19088 with windows 7 Home Premium, it seems to crash SkyDemon Plan on first use, with an info box from Windows that just closes SkyDemon, although if you open SkyDemon again it them seems to function perfectly well.
Steve
Aero AT3-R100, C172 Skyhawk, EGBK Sywell
pauldgardner
pauldgardner
Posts: 13, Visits: 43
I have just installed a clean version of Windows 7 and installed Sky Demon Plan  vers 09.13.26857 and have the same problems as others.
As soon as I click on the second spot to make a route the programme crashes. It does this every time.
Paul
Steve
Steve
I found the same issue, if you make a manual route using 'F4' this will then allow the software to function afterwards with a mouse click.
I'm pleased to say we've managed to locate and fix this problem. Really strange one, too.
pauldgardner
pauldgardner
I am pleased that you have found the bug !
Any idea when the revised version will be available?
Paul
SkyDemon was released this morning.
