Skydemon generated gfp to SDcard for Garmin GTN-750
danielderoeck
danielderoeck
Too Much Forum (228 reputation)Too Much Forum (228 reputation)Too Much Forum (228 reputation)Too Much Forum (228 reputation)Too Much Forum (228 reputation)Too Much Forum (228 reputation)Too Much Forum (228 reputation)Too Much Forum (228 reputation)Too Much Forum (228 reputation)
Posts: 1, Visits: 6
Does anyone have experience to transfer a flight plan via SD card to a Garmin GTN-750. I did use the 'save as Garmin GTN' option to generate the gfp file, and copied it to an 8 GB SD card, FAT32 formatted, but the GTN-750 did not recognize it.
Does it need to be saved in a certain folder on the SD card?
In the past, I had no problems in transferring the *.fpl files to an SD card to use in a Garmin GX3.
PS I really do like Sky demon!
I fly a Tecnam P2002JR
Pete
Pete
Posts: 129, Visits: 966
Did you find the answer to this?
James Morrey
James Morrey
Posts: 17, Visits: 42
We had a similar problem. I've managed to find the solution on a third party website.
The .gfp file has to be in a folder called 'FPL' on the SD card. Then the import option is available on the Garmin unit.
Just bear in mind that Garmin doesn't like waypoints that are in the middle of nowhere.
thierryr65
t
Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)
Posts: 2, Visits: 0
danielderoeck - 10/6/2015 8:57:21 PM
just try to format your SD card as FAT DOS (Fat16) or try to find an old SD card of 1, 2 or 4 gb by old cards used this type or format and when we try to use a modern one or format most of the time that's FAT32
Thierry
