Index out of range
pmh
pmh
Posts: 17, Visits: 43
I'm really impressed with the winds aloft feature.
While exploring the beta I'm getting this error: (I hope you can see what it is even if some of the text are in Danish)
Se slutningen af denne meddelelse, hvis du vil have detaljer om,
hvordan du starter JIT-fejlfinding i stedet for denne dialogboks.
************** Undtagelsestekst **************
System.IndexOutOfRangeException: Indekset lå uden for arrayets grænser.
   ved Divelements.Aviation.Weather.Forecasts.WindGrid.GetWind(EarthPosition position)
   ved Divelements.Aviation.Weather.x522b997f841f26fe.xe5df40271ae13a07(EarthPosition x13d4cb8d1bd20347, VerticalPosition x66bbd7ed8c65740d)
   ved Divelements.Aviation.Weather.xc8d58c4a54accb55.xe5df40271ae13a07(DateTime x0ebe150470f7718d, EarthPosition x13d4cb8d1bd20347, VerticalPosition x66bbd7ed8c65740d)
   ved Divelements.Aviation.MapOverlays.x3c3394c74e21cd79.x6dd4cfc9aec2976d(Graphics x41347a961b838962, VerticalPosition x66bbd7ed8c65740d)
   ved Divelements.Aviation.MapOverlays.x3c3394c74e21cd79.Draw(Graphics graphics)
   ved Divelements.Aviation.FlightPlanner.Rendering.x970ba8497cedc724.OnPaint(PaintEventArgs e)
   ved System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   ved System.Windows.Forms.Control.WmPaint(Message& m)
   ved System.Windows.Forms.Control.WndProc(Message& m)
   ved Divelements.Aviation.FlightPlanner.Rendering.x5cf3c184e49e0afe.WndProc(Message& m)
   ved System.Windows.Forms.Control.ControlNativewindow.WndProc(Message& m)
   ved System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Indlæste assemblies **************
mscorlib
    Assemblyversion: 2.0.0.0
    Win32-version: 2.0.50727.4952 (win7RTMGDR.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
SkyDemon
    Assemblyversion: 1.4.5.32593
    Win32-version:
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SkyDemon.exe
    Assemblyversion: 1.0.4034.32591
    Win32-version: 1.0.4034.32591
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
    Win32-version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Divelements.SandGrid
    Assemblyversion: 2.2.4.1
    Win32-version: 2.2.4.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
SandDock
    Assemblyversion: 3.0.6.1
    Win32-version: 3.0.6.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandDock.DLL
Divelements.Mapping
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
mscorlib.resources
SandBar
    Assemblyversion: 1.4.3.1
    Win32-version: 1.4.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandBar.DLL
Accessibility
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Windows.Forms.resources
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_da_b77a5c561934e089/System.Windows.Forms.resources.dll
************** JIT-fejlfinding **************
Hvis du vil aktivere JIT-fejlfinding, skal værdien jitDebugging indstilles
i afsnittet system.windows.forms i konfigurationsfilen
for programmet eller computeren.
Programmet skal desuden kompileres med fejlfinding
aktiveret.
Eksempel:
<configuration>
</configuration>
Når JIT-fejlfinding er aktiveret, bliver alle ikke-afviklede
undtagelser sendt til den JIT-fejlfindingsfunktion, der er registreret på computeren, i stedet for
at blive afviklet af denne dialogboks.
Posts: 8.2K, Visits: 9.5K
Thanks for reporting this. Can you help us by explaining what actions are required to generate this error? We haven't heard any other reports of it, though we will do some tests in Danish airspace.
pmh
pmh
I have reproduced this error creating a route from EKBR to EFMA.
When zooming in around Stockholm after the arrows for winds aloft have been shown I get this error.
Peter
Is that a direct route? What exactly needs to be zoomed in on, and at what level? Unfortunately we haven't managed to reproduce this yet here, though we are trying!
Never mind, we found the problem. Thanks!
