GAR for Isle of Man?
VMC-on-top
VMC-on-top
Posts: 19, Visits: 62
Planning to visit the IOM for the TT end of next week and wanting to file GAR. I recall when i went last year, the option to file from SD under "flight details" section was there but doesn't appear now?
Has this changed since last year - and if not, where can i find it?
thanks.
srayne
srayne
Posts: 388, Visits: 8.3K
I you're flying from a designated airport then a GAR is not required and the option will not be shown. Try changing your dearture airport and see if the GAR option appears again. Where are you flying from?
Take a look at https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/412944/GAR_Instructions_March_2015.pdf
Edited 6/1/2015 10:36:52 AM by srayne
VMC-on-top
VMC-on-top
Thanks - Departing from Newcastle EGNT which is customs. It is more the fact that IOM require a copy of the GAR to be sent direct to them as they report they don't receive electronic copies submitted by other methods.
thanks.
srayne
srayne
I've just seen this (https://www.onlinegar.com/support.olg?opt=whereitgoes) which says that for IOM you need to fill out the form using Online GAR site and send it to them manually.
