1.5 beta
pink leader
pink leader
Posts: 518, Visits: 2K
Absolutely love the print centre. Anyway you could get it to print everything? Also seems you cannot select page ranges to print (not on a HP CP1215 anyway). Could be handy.
Has the formation flight NOTAM route function disappeared? There was a ceremonial flight today around Brize. Was in the printout but nothing showed on the map.
Re Flight Plans does this mean AFPEX setup becomes redundant? Hope so as it seems pretty cumbersome. But there is a greyed out bit re Account Credits  .. sounds ominously like another subscription coming. Can you enlighten please?
Anyway great stuff re print centre.
D
Posts: 8.1K, Visits: 9.3K
There won't be an "everything" button in this release but we will certainly consider adding one later if there proves to be demand (which I suspect there will). Selectable page ranges is the same story I'm afraid.
The formation flight plotting function hasn't changed; unfortunately the NOTAM you mentioned has gone now. If you email us the minute you suspect there is one that we're not plotting but should be, we'll have a good chance of finding the answer for you.
Our flightplan support should make AFPEx redundant, yes. We'll turn the feature on over the weekend I expect. It'll be credit based as it costs us money, but will only cost £1 per plan which will include the ability to cancel/delay/close it.
Hope this answers your queries!
stuartforrest
stuartforrest
Too Much Forum (6.4K reputation)Too Much Forum (6.4K reputation)Too Much Forum (6.4K reputation)Too Much Forum (6.4K reputation)Too Much Forum (6.4K reputation)Too Much Forum (6.4K reputation)Too Much Forum (6.4K reputation)Too Much Forum (6.4K reputation)Too Much Forum (6.4K reputation)
Posts: 59, Visits: 108
Seems pretty reasonable to me as I find filing flight plans a pain in the a$#e.
My plane uses over 100 quid an hour in fuel and takes so any flight is likely to be costing a bundle more than the flight does!
Beech Bonanza A36 Based at Blackpool
G-FOZZ www.gotoair.com
derekf
derekf
Posts: 39, Visits: 193
Tim - I see from the news article that the flight plan filing is being done via EuroFPL. If we already have EuroFPL accounts (I've a premium account) is there a way of filing the flight plan with them through SkyDemon using our 'own' account so that we don't have to pay you for it (as we've alreay paid EuroFPL with our account)?
Dan P
Dan P
Too Much Forum (681 reputation)Too Much Forum (681 reputation)Too Much Forum (681 reputation)Too Much Forum (681 reputation)Too Much Forum (681 reputation)Too Much Forum (681 reputation)Too Much Forum (681 reputation)Too Much Forum (681 reputation)Too Much Forum (681 reputation)
Posts: 9, Visits: 212
Hi Tim / Team.
Have udated to the latest beta and the imprevements are great Smile
Only one problem when you now try to adjust your planned altitude in the enroute features window by dragging the line up or down you recieve this error window
I have pasted entire fault code
System.ArgumentException: TimeSpan does not accept floating point Not-a-Number values.
   at System.TimeSpan.Interval(Double value, Int32 scale)
   at Divelements.Aviation.Routing.FlightModelUtilities.ProcessIntermediateClimbOrDescent(List`1 entries, Int32 targetIndex, Boolean climb, IFlightModelDataSupply dataSupply, FlightPerformanceClimbProfile climbProfile, FlightPerformanceDescentProfile descentProfile)
   at Divelements.Aviation.Routing.FlightModelUtilities.ProcessIntermediateClimbsAndDescents(List`1 entries, IFlightModelDataSupply dataSupply, FlightPerformanceClimbProfile climbProfile, FlightPerformanceDescentProfile descentProfile)
   at Divelements.Aviation.Routing.FlightModelUtilities.RunFlightModel(RhumbLineLeg[] legs, IFlightModelDataSupply dataSupply, FlightPerformanceClimbProfile climbProfile, FlightPerformanceDescentProfile descentProfile)
   at Divelements.Aviation.Routing.Journey.CreateModel()
   at Divelements.Aviation.Routing.Journey.get_Model()
   at Divelements.Aviation.Routing.PlannedRouteParameters..ctor(Journey journey, GeometryEntity[] airspace, Entity[] positionedEntities)
   at Divelements.Aviation.FlightPlanner.Routing.x623a54d0e478ee0f.xa3c6ce19704d4032()
   at Divelements.Aviation.FlightPlanner.Routing.x623a54d0e478ee0f.x2f58c73044db3fb6(Object xe0292b9ed559da7d, RouteChangeEventArgs xfbf34718e704c6bc)
   at System.EventHandler`1.Invoke(Object sender, TEventArgs e)
   at Divelements.Aviation.Routing.Journey.OnRouteChanged(RouteChangeEventArgs e)
   at Divelements.Aviation.Routing.Journey.OnGeographyChanged()
   at Divelements.Aviation.Routing.RhumbLineLeg.GeographyChanged()
   at Divelements.Aviation.Routing.RhumbLineLeg.set_Level(VerticalPosition value)
   at Divelements.Aviation.FlightPlanner.Rendering.x2f1599f2099aaa05.OnMouseUp(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativewindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativewindow.WndProc(Message& m)
   at System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.3615 (GDR.050727-3600)
    CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SkyDemon
    Assembly Version: 1.4.5.20583
    Win32 Version:
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SkyDemon.exe
Divelements.SandGrid
    Assembly Version: 2.2.4.1
    Win32 Version: 2.2.4.1
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
    Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 2.0.50727.3614 (GDR.050727-3600)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
SandDock
    Assembly Version: 3.0.6.1
    Win32 Version: 3.0.6.1
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandDock.DLL
    Assembly Version: 1.0.4024.20581
    Win32 Version: 1.0.4024.20581
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
Divelements.Mapping
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
System.Xml
    Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
SandBar
    Assembly Version: 1.4.3.1
    Win32 Version: 1.4.3.1
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandBar.DLL
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
enabled.
For example:
<configuration>
</configuration>
Derek, EuroFPL only provide the gateway we use to submit plans via the AFTN. We have nothing to do with their "normal" service and any account you have with them will be completely independent of SkyDemon.
Dan, thanks, I believe this was a bug fixed in today's beta release.
