Visits: 2.6K
Hi Pete,
I have tried that but cannot move the "instrument". It appears fixed at the lower portion of the display (on my Samsung S4), with perhaps only the top 1cm of the instrument showing. I can move it on my Nexus 7 (which isn't used in flight), so must be something to do with the different flavours of Android.
Also, should I have been able to move the instrument to display it in full on my S4 then: 1. It would all but completely cover the map 2. If shrunk down then the text and heading bug gets so small it is barely viewable. 3. It would be very fiddly to "move" the instrument in flight.
If my suggestion could be incorporated, then I believe the toggling between the display should be as simple in possible and -"in-flight" friendly. Perhaps a tab labeled "I" to accompany the "N", "W", "P" and "F"? Tony
