Notam filtering
Adri17
Adri17
Too Much Forum (241 reputation)Too Much Forum (241 reputation)Too Much Forum (241 reputation)Too Much Forum (241 reputation)Too Much Forum (241 reputation)Too Much Forum (241 reputation)Too Much Forum (241 reputation)Too Much Forum (241 reputation)Too Much Forum (241 reputation)
Posts: 2, Visits: 8
I'm currently a very attached user to sky demon, I find this app super useful while preparing and flying, especially with the Motam highlight feature, this gives you a quick overview of what is going on on the route/destination regarding restricted zones/military (I fly Belgium and north east of France)
But some times (like it happened to me 2 weeks ago) there are first some circle that declares all notams for an area and then the zones itself highlighted which is good but when your flying and you got 3/4 circle with a pretty large radius in red and restricted zone in red it's pretty confusing..
Ence a suggestion a thought ( may its already available, or some one raised it already) is a possibility of selecting notam to show in order to dismiss general zone notam (big red circle) and only show current activated zone (and not both)
Thanks for the reading and I hope you will continue the great work you are doing with this app !!
A.
Ps: I uploaded a screen shot of it might help understanding...
I think those are two separate NOTAM, no? If a NOTAM is activating a danger area(s) then it should not also have a circle.
Unfortunately, the French authorities often publish one large NOTAM referring to many different areas or activations, which is not helpful.
Adri17
Adri17
Posts: 2, Visits: 8
Ok I see the problem (actually my screen is from belgium which have the same aggregate area activation message) so maybe adding a "notam map selection" might fix this double presence on screen ?  Or some think like manual selection of active zone so we can choose whether to show automatically activated zones (and in this case having sometimes for example in france the big circle) or to choose which zone to highlight ..
Tx for the answer
A.
