Any Mooney M20 profiles out there?
Peter
Peter
Posts: 14, Visits: 63
Profiles for M20J 201 and 205 models are appreciated!
Happy landings, Peter
DutchAviator
DutchAviator
Posts: 9, Visits: 78
I've made one for a M20K-252
Is that of any help?
(if yes: pls instruct how to export this)
kindest regards
DutchAviator
DutchAviator
Second attemt:
save this file as "WhatEverName.aircraft"
As said it's for the M20K, so you need to alter some of the values but can give you a quick start
Also double check the all relevant data according to your needs.
kindest regards,
<?xml version="1.0" encoding="utf-8"?>
<Aircraft Name="Mooney M20K-252" Registration="PH-XXX" FuelType="AvGas100LL" AlternateFuelType="None" FuelMeasurementType="Volume" FuelMeasurementVolumeType="Litres" FuelMeasurementMassType="Kilograms" TaxiFuel="6.000000" LandingFuel="1.000000" MaxFuel="286.000000" EmptyWeight="939.979468" EmptyArmLon="112.83" EmptyArmLat="0.00" Type="M20T" ColourMarkings="WHITE AND BLUE" ServiceCeiling="24000" Equipment1="DFGLOVY" Equipment2="S" OtherCommsEquipment="" OtherNavEquipment="" PbnEquipment="" FuelContingency="0.05" HoldingMinutes="45" HourlyCost="212" HourlyCostIncludesFuel="False" GlideAirspeed="85.00" GlideRatio="12.00" DefaultLevel="18000" Envelope="103.05,939.979468,103.05,1072.020207,110.20,1315.009640,125.20,1315.009640,125.20,939.979468">
<ClimbProfile FpmSL="800.000000" FpmSC="500.000000" IndicatedAirspeed="105.000000" FuelBurnSL="60.000000" FuelBurnSC="60.000000" />
<DescentProfile Fpm="-700.000000" IndicatedAirspeed="170.000000" FuelBurn="20.000000" />
<CruiseProfiles>
  <CruiseProfile Name="65% - SL" FuelBurn="39.700000" IndicatedAirspeed="144.000000" Airspeed="144.000000" AirspeedType="True" />
  <CruiseProfile Name="65% - FL040" FuelBurn="39.700000" IndicatedAirspeed="150.000000" Airspeed="150.000000" AirspeedType="True" />
  <CruiseProfile Name="65% - FL080" FuelBurn="39.700000" IndicatedAirspeed="151.000000" Airspeed="151.000000" AirspeedType="True" />
  <CruiseProfile Name="65% - FL120" FuelBurn="39.700000" IndicatedAirspeed="162.000000" Airspeed="162.000000" AirspeedType="True" />
  <CruiseProfile Name="65% - FL160" FuelBurn="39.700000" IndicatedAirspeed="167.000000" Airspeed="167.000000" AirspeedType="True" />
  <CruiseProfile Name="65% - FL180" FuelBurn="39.700000" IndicatedAirspeed="170.000000" Airspeed="170.000000" AirspeedType="True" />
  <CruiseProfile Name="65% - FL200" FuelBurn="39.700000" IndicatedAirspeed="173.000000" Airspeed="173.000000" AirspeedType="True" />
  <CruiseProfile Name="65% - FL240" FuelBurn="39.700000" IndicatedAirspeed="176.000000" Airspeed="176.000000" AirspeedType="True" />
</CruiseProfiles>
<LoadingPoints>
  <FuelLoadingPoint Name="Fuel" LeverArm="123.39" LeverArmLat="0.00" DefaultValue="160.00" Capacity="286.00" />
  <LoadingPoint Name="Pilot" LeverArm="89.62" LeverArmLat="0.00" DefaultValue="114.00" />
  <LoadingPoint Name="Navigator" LeverArm="86.38" LeverArmLat="0.00" DefaultValue="63.00" />
  <LoadingPoint Name="Rear Passenger" LeverArm="179.60" LeverArmLat="0.00" DefaultValue="0.00" />
  <LoadingPoint Name="Baggage" LeverArm="242.60" LeverArmLat="0.00" DefaultValue="15.00" />
  <LoadingPoint Name="Hat Rack" LeverArm="302.30" LeverArmLat="0.00" DefaultValue="5.00" />
</LoadingPoints>
neilmurg
neilmurg
Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)Too Much Forum (5K reputation)
Posts: 43, Visits: 128
does this help?
MooneyM20K-252.aircraft (968 views, 2.00 KB)
