airport not showing on VFR map
poorterp
poorterp
Posts: 28, Visits: 93
Hi Skydemon team,
I wanted to prepare a flight to EDKA (aachen-merzbruck airport) and took out the IPAD. To my surprise this airport wasnt there.
In the PC there was no problem but on the IPAD the airport doesnt show up. When I switch to the IFR airways map the
airport is there. Any idea?
Greetz Peter
Posts: 593, Visits: 4.9K
Try zooming in and out. It's probably there but being hidden due to clutter on the screen.
poorterp
poorterp
No, I zoomed in very much and the only icon shown at the airports location is a parashute. The runway symbol and name of the airport are not there. I have taken 2 screenshots at 1:80000 scale from VFR and IFR maps.
If needed I can send them...
Edited 10/10/2014 9:29:09 AM by poorterp
I can see the airport ID of EDKA on my iPad. Did you check if you have an active airport filter set?
poorterp
poorterp
if I have its unintentional as I dont know how to set a filter on airports
poorterp
poorterp
solved....
i had changed somewhere the minimum runway length to 600 meter and EDKA is shorter.
when i tried to set that back I changed to runway length for direct to and not the one in the
mapping item....
