Open route from cloud
nje
nje
Posts: 384, Visits: 4.2K
I'm not sure if the following is a result of the latest update from Apple or not but when opening a route from cloud it now requires you to double up on actions.
E.g.
Click - route and you then see the drop down list.
Click - Open from cloud, you now see 'open from cloud' with an arrow to the left directing you to 'route'
Click - route, and you get the drop down list again.
Click - Open from cloud (again) and then you can open from cloud.
Not a major problem, more a minor inconvenience but I don't think it happened before the update.
Anyone else experienced it
Bouwair
Bouwair
Posts: 39, Visits: 2.8K
The same here. Something must have changed.
I also work with the latest Ipad update
Andyt
Andyt
Too Much Forum (828 reputation)Too Much Forum (828 reputation)Too Much Forum (828 reputation)Too Much Forum (828 reputation)Too Much Forum (828 reputation)Too Much Forum (828 reputation)Too Much Forum (828 reputation)Too Much Forum (828 reputation)Too Much Forum (828 reputation)
Posts: 6, Visits: 305
And here !
Harald
Harald
Posts: 7, Visits: 3
Looks like a general bug in current iOS and is not only limited to Skydemon ... here too.
Bouwair
Bouwair
Updated to iOS 8.02 solved the problem
It's an iOS issue but the next version of SkyDemon (and indeed the fixed iOS alluded to above) will fix it.
nje
nje
Thanks Tim, appreciated
