Persistent bearing display
pseudonym
pseudonym
Posts: 50, Visits: 189
I see track in the upper instrument row
Bearing is only depicted when it is in +-40° of the track. If you're either lost or have to perform a change in heading of more than 45°, you don't see the bearing anymore.
A Solution might be the way Dynon handles this: they display +-30° too, but the bearing indicator stays at the corner of the scale, half present, indicating the direction to turn to. On SD, the bearing indicator disappears, which I find less fortunate
Too Much Forum (67K reputation)Too Much Forum (67K reputation)Too Much Forum (67K reputation)Too Much Forum (67K reputation)Too Much Forum (67K reputation)Too Much Forum (67K reputation)Too Much Forum (67K reputation)Too Much Forum (67K reputation)Too Much Forum (67K reputation)
You can drag the HSI up from the bottom and display a full 360 deg.
pseudonym
pseudonym
Got it, thanks!
