SkyDemon Flight Planning
Cloning Aircraft profiles on iPad?
joanna
joanna
posted 6/11/2014 10:26:10 AM
Visits: 34
Is it possible to clone (copy) a user-customized aircraft profile on the iPad Sky Demon? This would be a very useful feature in case somebody flies two or more aircraft of the same type, where most of the properties are the same, yet different profiles are still requires (e.g. for the purpose of M&B, flight plan filling, etc).
I understand that the above is possible on the PC edition of the Sky Demon by manually copying of the Aircraft's directory, but has the obvious disadvantage of requiring a PC...
Thanks,
joanna.
Tags
aircraft profiles cloning ipad
posted 6/11/2014 3:34:16 PM
Visits: 15K
Hi Joanna
Take a look at this thread:-
http://www.skydemon.aero/forums/Topic12362.aspx#bm12373
It may help you.
Samsung Galaxy Tab A8 – Android 11.0 & SD
4.2.3
26200.7840
, SD 4.2.3
joanna
joanna
posted 6/11/2014 9:57:56 PM
Visits: 34
Indeed, saving the aircraft "to the cloud", then opening from the cloud and renaming seems to do exactly what I wanted.
Thanks!
joanna.
