Skydemon Plan on Mac
peter@moonpython.com
Too Much Forum (140 reputation)Too Much Forum (140 reputation)Too Much Forum (140 reputation)Too Much Forum (140 reputation)Too Much Forum (140 reputation)Too Much Forum (140 reputation)Too Much Forum (140 reputation)Too Much Forum (140 reputation)Too Much Forum (140 reputation)
Posts: 1, Visits: 2
That customer would be me!!
Tags
Rob Hart
Rob Hart
SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)SkyDemon Team (9.6K reputation)
Posts: 77, Visits: 454
Steve, I received a report from a Mac-version user who is seeing an "unhandled error" message when he tries to view a flight-log in Google Earth.
Have you encountered this before? Any ideas on a workaround?
Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)
Posts: 593, Visits: 4.9K
I'll take a look tonight for you.
Wolfgang Müller
Wolfgang Müller
Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)
Posts: 1, Visits: 11
Dear all,
i´m now installed SkyDemon on my IMac.
In the Setup Menu i wanted to edit my Aircraft (Vans RV-8).
Everytime when i changed the Aircraft Properties and when i want to storage the values i pressed the quit button. But this stops completely the Programm and i have to restart the Computer to start SkyDemon.
Do you have an idea?
Wolfganghttp://forums.skydemon.aero/uploads/images/ec8a9fbc-ff21-43c1-b7d1-fd36.jpg
Edited 10/7/2014 7:55:30 PM by Wolfgang Müller
Hi Folks,
Just to let you know, I've updated this to the latest version (3.1.0) and PDFs now open correctly using your default PDF viewer.
To install (or upgrade), just open the DMG file and drag the SkyDemon icon into your Applications folder. Please note that it will not work if you try and execute it directly from the DMG file.
Print Centre works fine as well. Please note that your printer must be present and working before launching SD. Just check it's visible in System Preferences > Printers and Scanners first.
This has been tested on Mavericks and Yosemite, but should work just fine on earlier OS X versions.
http://skydemon.aero/start/macosx.aspx
Regards,
Steve
Edited 10/6/2014 4:16:52 PM by stevelup
Snuggles78
Snuggles78
Too Much Forum (178 reputation)Too Much Forum (178 reputation)Too Much Forum (178 reputation)Too Much Forum (178 reputation)Too Much Forum (178 reputation)Too Much Forum (178 reputation)Too Much Forum (178 reputation)Too Much Forum (178 reputation)Too Much Forum (178 reputation)
Posts: 1, Visits: 6
Thank you for programming this!
Good work.
tijssel
tijssel
Posts: 21, Visits: 307
I still have problems with PDF even if I start Adobe first the PDF will not open.
Stevelup, how did you solve this problem?
Tags
guille
guille
Posts: 149, Visits: 2.4K
Good news! it is great to have SD directly on the Mac ...
That's good to know.
I've got PDF viewing working now as well - they open in whatever your default Mac PDF viewer is.
I'm working on some other bits so won't update the build on my Google Drive just yet.
guille
guille
I just tested again and the Print Centre seems to work properly now.
