Skydemon Plan on Mac
guille
guille
Posts: 149, Visits: 2.4K
I found a problem : it does not recognize a reader for pdf. Neither the one included in the Mac (preview) nor Acrobat reader.
stevelup
stevelup
Group: Moderators
Posts: 593, Visits: 4.9K
I'm aware of this and working on it. I may have to include a 'Windows' PDF viewer in the application bundle. I really wanted it to open PDFs in the default OS X PDF viewer but this proved problematic.
I'll look at Print Centre later. In fact, I doubt that printing works at all. Other stuff is probably broken as well such as sending via e-mail.
Please have a good play and post back here with any problems you discover. If they are not obvious, please detail the steps to reproduce.
Really a good job! When is it going to be "official"?
This is nothing at all to do with the SD team - it's something I've done in my spare time.
guille
guille
What is strange is that I have Adobe Acrobate Reader on my Mac, and it does not work. Anyway, it is great what you manage to do on your spare time!
stevelup
stevelup
Group: Moderators
Personally, I think the built-in Apple Preview.app is better than Adobe Reader so I've been focussing on getting that working. It's also available on all systems. I'll let you know when I've cracked it.
guille
guille
I just tested again and the Print Centre seems to work properly now.
stevelup
stevelup
Group: Moderators
That's good to know.
I've got PDF viewing working now as well - they open in whatever your default Mac PDF viewer is.
I'm working on some other bits so won't update the build on my Google Drive just yet.
guille
guille
Good news! it is great to have SD directly on the Mac ...
tijssel
tijssel
Posts: 21, Visits: 307
I still have problems with PDF even if I start Adobe first the PDF will not open.
Stevelup, how did you solve this problem?
Tags
Snuggles78
Snuggles78
Too Much Forum (178 reputation)Too Much Forum (178 reputation)Too Much Forum (178 reputation)Too Much Forum (178 reputation)Too Much Forum (178 reputation)Too Much Forum (178 reputation)Too Much Forum (178 reputation)Too Much Forum (178 reputation)Too Much Forum (178 reputation)
Posts: 1, Visits: 6
Thank you for programming this!
Good work.
stevelup
stevelup
Group: Moderators
Hi Folks,
Just to let you know, I've updated this to the latest version (3.1.0) and PDFs now open correctly using your default PDF viewer.
To install (or upgrade), just open the DMG file and drag the SkyDemon icon into your Applications folder. Please note that it will not work if you try and execute it directly from the DMG file.
Print Centre works fine as well. Please note that your printer must be present and working before launching SD. Just check it's visible in System Preferences > Printers and Scanners first.
This has been tested on Mavericks and Yosemite, but should work just fine on earlier OS X versions.
http://skydemon.aero/start/macosx.aspx
Regards,
Steve
Edited 10/6/2014 4:16:52 PM by stevelup
