SD Exits When in Flight on Nexus 7 32 Gb (Android v 4.4.2 SD Version 3.0.6.17809)
SD Exits When in Flight on Nexus 7 32 Gb (Android v 4.4.2 SD Version...
alberto
alberto
Posts: 20, Visits: 291
Today had a 3 hour flight with the Nexus 7 that crashes often in the past. I had no crash at all! I used the offical 3.0.6 after I tested several betas.
So for me, it looks as the charts could have brought and removed the problem.
The charts are not responsible for instability. This is just the inconsistency seen in general on the Android platform. Remember, most people running 3.0.6 do not have a problem with instability.
Pete
Pete
Posts: 129, Visits: 966
Well I'm also having problems, as is another user I know.
The problem I'm having is that SD just shuts down, usually shortly after opening, particularly when switching to "go flying" straight after opening(as you do when going flying!).
I never had a problem until more recent updates. I have tried resetting my nexus and all seemed well until further apps were added.
Hopefully the new ver will address these problems, I tried monday's beta but found some of the setup menus locked up.
Pete
MikeTwoOne
MikeTwoOne
Posts: 147, Visits: 2.1K
Considering SD is not generating any crash report, I'm not sure we can state that most people do not have a problem.
The only thing we can say is that most people are not complaining. Which is different since all the users I know (6 people) are complaining for months.
Anyway, the last beta is a huge improvement. I had a 2 hours flight yesterday without any crash!
M
alberto
alberto
I believe many users have problems, but they do not comply. I also did so at beginning and thought it was my problem, perhaps having touched somethin on the tablet.
Gerhard
Gerhard
Too Much Forum (139 reputation)Too Much Forum (139 reputation)Too Much Forum (139 reputation)Too Much Forum (139 reputation)Too Much Forum (139 reputation)Too Much Forum (139 reputation)Too Much Forum (139 reputation)Too Much Forum (139 reputation)Too Much Forum (139 reputation)
Posts: 1, Visits: 7
Android on Nexus 7, version 4.4.2, SkyDemon 3.0.6.17809
Same problem - SD stops during logging GPS Data, starts program again with start screen but does not continue logging.
Gerhard
Bluebeard
Bluebeard
Posts: 26, Visits: 128
I have the same problem with Nexus 7. Skydemon crashes randomly every couple of hours, sometimes at a time when awareness of position in local airspace is critical. This is not really a sustainable situation, if it is not sorted out I will have to consider going over to the dark side and getting an Ipad ..........
Please try the beta people have already mentioned. It should solve the most common cause of in-flight instability.
ptessier
ptessier
Posts: 1, Visits: 20
Hi all
As I have the exact same issue on 3.0.6 installed on a Nexus 7 and I wish to understand what's going on I have captured an Android logcat trace just after a crash from SD which is often at starts of applicaiton but also in middle of in flight navigation.
I hope this could help to solve the issue.
(Sorry for this long message with the dump)
I/ProcessStatsService( 515): Prepared write state in 15ms
W/GLSUser ( 889): GoogleAccountDataService.getToken()
I/ProcessStatsService( 515): Pruning old procstats: /data/system/procstats/state-2014-05-31-17-43-16.bin
E/PlayEventLogger( 1477): Upload failed class java.net.UnknownHostException(Unable to resolve host "play.googleapis.com": No address associated with hostname)
D/dalvikvm( 789): GC_CONCURRENT freed 1609K, 31% free 12987K/18660K, paused 1ms+2ms, total 30ms
D/dalvikvm( 789): WAIT_FOR_CONCURRENT_GC blocked 17ms
I/ActivityManager( 515): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 pkg=aero.skydemon.skydemonandroid cmp=aero.skydemon.skydemonandroid/divelements.skydemon.SplashActivity bnds=[16,755][144,883]} from pid 789
I/UsageStats( 515): Deleting usage file : usage-20140516
D/dalvikvm( 515): GC_FOR_ALLOC freed 1166K, 25% free 16359K/21712K, paused 90ms, total 91ms
I/dalvikvm-heap( 515): Grow heap (frag case) to 20.445MB for 4645120-byte allocation
D/dalvikvm( 515): GC_FOR_ALLOC freed 2K, 21% free 20892K/26252K, paused 135ms, total 135ms
I/Choreographer( 515): Skipped 39 frames! The application may be doing too much work on its main thread.
W/InputMethodManagerService( 515): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@427077f8 (uid=10035 pid=789)
I/ActivityManager( 515): Displayed aero.skydemon.skydemonandroid/divelements.skydemon.SplashActivity: +810ms
D/dalvikvm( 515): GC_CONCURRENT freed 11K, 21% free 20898K/26252K, paused 4ms+37ms, total 281ms
I/ActivityManager( 515): START u0 {cmp=aero.skydemon.skydemonandroid/divelements.skydemon.Activity1} from pid 2218
I/UsageStats( 515): No package stats for pkg:aero.skydemon.skydemonandroid
I/mono-stdout( 2218): Skipped loading NOTAMs for LFEE: data expired
I/mono-stdout( 2218): Skipped loading NOTAMs for EDGG: data expired
D/dalvikvm( 2218): GC_EXPLICIT freed 87K, 44% free 24565K/43148K, paused 2ms+4ms, total 27ms
I/Choreographer( 2218): Skipped 334 frames! The application may be doing too much work on its main thread.
D/dalvikvm( 2218): GC_CONCURRENT freed 34K, 31% free 30050K/43148K, paused 2ms+3ms, total 24ms
I/ActivityManager( 515): Displayed aero.skydemon.skydemonandroid/divelements.skydemon.Activity1: +6s115ms
I/Choreographer( 2218): Skipped 93 frames! The application may be doing too much work on its main thread.
W/ProcessCpuTracker( 515): Skipping unknown process pid 12133
W/ActivityManager( 515): Launch timeout has expired, giving up wake lock!
D/dalvikvm( 2218): GC_EXPLICIT freed 294K, 20% free 34767K/43148K, paused 2ms+4ms, total 29ms
I/mono-stdout( 2218): slow rendering (4115): Obstruction, Mast
I/mono-stdout( 2218): charts: 161
D/dalvikvm( 2218): GC_EXPLICIT freed 1158K, 21% free 34281K/43148K, paused 2ms+5ms, total 30ms
I/mono-stdout( 2218): whole render: 603
I/mono-stdout( 2218): Clipping: 0 to 4000
I/mono-stdout( 2218): Clipping: 0 to 6000
D/dalvikvm( 2218): GC_FOR_ALLOC freed 139K, 21% free 34187K/43148K, paused 20ms, total 20ms
I/dalvikvm-heap( 2218): Grow heap (frag case) to 36.095MB for 2803216-byte allocation
D/dalvikvm( 2218): GC_FOR_ALLOC freed 1K, 20% free 36922K/45888K, paused 19ms, total 19ms
D/dalvikvm( 2218): GC_FOR_ALLOC freed 5K, 20% free 36924K/45888K, paused 19ms, total 19ms
I/dalvikvm-heap( 2218): Grow heap (frag case) to 38.769MB for 2803216-byte allocation
D/dalvikvm( 2218): GC_FOR_ALLOC freed 0K, 19% free 39662K/48628K, paused 20ms, total 20ms
E/mono-rt ( 2218): Stacktrace:
E/mono-rt ( 2218):
E/mono-rt ( 2218): at <unknown> <0xffffffff>
E/mono-rt ( 2218): at (wrapper managed-to-native) object.wrapper_native_0x417f1687 (intptr,intptr,intptr,Android.Runtime.JValue[]) <0xffffffff>
E/mono-rt ( 2218): at (wrapper delegate-invoke) <Module>.invoke_void__this___intptr_intptr_intptr_JValue[] (intptr,intptr,intptr,Android.Runtime.JValue[]) <0xffffffff>
E/mono-rt ( 2218): at Android.Runtime.JNIEnv.CallVoidMethod (intptr,intptr,Android.Runtime.JValue[]) <0x00097>
E/mono-rt ( 2218): at Android.Graphics.Canvas.DrawPath (Android.Graphics.Path,Android.Graphics.Paint) <0x0018f>
E/mono-rt ( 2218): at Divelements.SkyDemon.Drawing.DrawingExtensions.FillPathEdges (Divelements.SkyDemon.Drawing.DrawingContext,Android.Graphics.Path,Divelements.SkyDemon.Drawing.SkyDemonBrush,single) <0x0024b>
E/mono-rt ( 2218): at Divelements.SkyDemon.Mapping.AirspaceRendering.RenderAirspace (Divelements.SkyDemon.Mapping.RenderEntityEventArgs,Divelements.Aviation.AirspaceEntity,Divelements.SkyDemon.Mapping.ChartRenderer,Divelements.Mapping.TwoDimensionalGeometry,single,Divelements.SkyDemon.Mapping.AirspaceFillRule,System.Collections.Generic.List`1<System.Collections.Generic.List`1<Divelements.Aviation.AirspaceEntity>>,Divelements.SkyDemon.Mapping.ChartFeatures) <0x0044b>
E/mono-rt ( 2218): at Divelements.SkyDemon.Mapping.AirspaceRendering.RenderAirspace (Divelements.SkyDemon.Mapping.RenderEntityEventArgs,Divelements.Aviation.AirspaceEntity,Divelements.SkyDemon.Mapping.ChartRenderer,Divelements.Mapping.TwoDimensionalGeometry,single,System.Collections.Generic.List`1<System.Collections.Generic.List`1<Divelements.Aviation.AirspaceEntity>>,Divelements.SkyDemon.Mapping.ChartFeatures) <0x0006f>
E/mono-rt ( 2218): at Divelements.SkyDemon.Mapping.CommonRenderer.DrawTwoDimensionalEntity (Divelements.SkyDemon.Mapping.RenderEntityEventArgs,Divelements.SkyDemon.Mapping.ChartRenderer,System.Collections.Generic.List`1<System.Collections.Generic.List`1<Divelements.Aviation.AirspaceEntity>>,System.Collections.Generic.List`1<Divelements.Aviation.AirwayRawSegment>,Divelements.SkyDemon.Mapping.ChartFeatures) <0x00237>
E/mono-rt ( 2218): at Divelements.SkyDemon.Mapping.AviationMapRenderer.OnRenderEntity (object,Divelements.SkyDemon.Mapping.RenderEntityEventArgs) <0x00273>
E/mono-rt ( 2218): at Divelements.SkyDemon.Mapping.MapRenderer.OnRenderEntity (Divelements.SkyDemon.Mapping.RenderEntityEventArgs) <0x00037>
E/mono-rt ( 2218): at Divelements.SkyDemon.Mapping.MapRenderer.Render (Android.Graphics.Bitmap,Divelements.SkyDemon.Drawing.DrawingContext,Divelements.SkyDemon.Mapping.MercatorProjection,single,Divelements.SkyDemon.Mapping.MapRenderCancellationToken) <0x00727>
E/mono-rt ( 2218): at Divelements.SkyDemon.Mapping.MapRenderer.RenderLoop () <0x004b3>
E/mono-rt ( 2218): at System.Threading.Thread.StartInternal () <0x0007f>
E/mono-rt ( 2218): at (wrapper runtime-invoke) object.runtime_invoke_void__this__ (object,intptr,intptr,intptr) <0xffffffff>
E/mono-rt ( 2218):
E/mono-rt ( 2218): =================================================================
E/mono-rt ( 2218): Got a SIGSEGV while executing native code. This usually indicates
E/mono-rt ( 2218): a fatal error in the mono runtime or one of the native libraries
E/mono-rt ( 2218): used by your application.
E/mono-rt ( 2218):
I/ActivityManager( 515): Process aero.skydemon.skydemonandroid (pid 2218) has died.
I/WindowState( 515): WIN DEATH: Window{42698988 u0 aero.skydemon.skydemonandroid/divelements.skydemon.Activity1}
W/ActivityManager( 515): Force removing ActivityRecord{426016e0 u0 aero.skydemon.skydemonandroid/divelements.skydemon.Activity1 t4}: app died, no saved state
W/Binder ( 730): Caught a RuntimeException from the binder stub implementation.
W/Binder ( 730): java.lang.NullPointerException
W/Binder ( 730): at android.inputmethodservice.IInputMethodWrapper.setSessionEnabled(IInputMethodWrapper.java:280)
W/Binder ( 730): at com.android.internal.view.IInputMethod$Stub.onTransact(IInputMethod.java:129)
W/Binder ( 730): at android.os.Binder.execTransact(Binder.java:404)
W/Binder ( 730): at dalvik.system.NativeStart.run(Native Method)
W/InputMethodManagerService( 515): Got RemoteException sending setActive(false) notification to pid 2218 uid 10080
D/Zygote ( 130): Process 2218 exited cleanly (255)
That issue is already solved, please see above.
