Adding unusable fuel in aircraft profile
KimW
K
Posts: 59, Visits: 0
I dont see the problem either. If the dry W&B does not include unusable fuel. Correct it with the arm and enter correct number into Skydemon. I see no reason for the software to cater for that.
PS: Apologies for the potential patronizing comment, my point was that the accuracy on the total W&B is not perfect, but I agree, why would you start with an error to  begin with.
miaelch
m
Too Much Forum (274 reputation)Too Much Forum (274 reputation)Too Much Forum (274 reputation)Too Much Forum (274 reputation)Too Much Forum (274 reputation)Too Much Forum (274 reputation)Too Much Forum (274 reputation)Too Much Forum (274 reputation)Too Much Forum (274 reputation)
Posts: 26, Visits: 4
The issue we are talking about is that the empty weight in SkyDemon does not include the unusable fuel, but the empty weight in real life does. I posted two possibilities how to deal with this. Maybe I didn't make clear enough the disadvantages of my method No. 2 (that is, to manually calculate the empty weight without fuel and the empty CG without fuel and to enter these values into SkyDemon).
1. I assume that most SkyDemon users are not aware of the fact that they have to do such calculations at all.
2. It introduces a source for calculation errors. The purpose of the W&B feature is that we do not have to calculate manually with moments.
3. It is impossible to check the correctness of the aircraft profile without calculating. If the aircraft profile is provided by a flight school or a flying club then you need to explain to everybody why it is indeed correct.
And yes, the error may be not so big. But at some point in time in the past it was decided that the unusable fuel is important enough to be included as a feature into SkyDemon. And in my opinion, if there is a feature then it should be correct.
Posts: 663, Visits: 32K
miaelch - 5/18/2026 11:11:41 AM
Surely the empty weight in SkyDemon is whatever you want it to be? It doesn’t decide for you whether unusable fuel is included or not.
miaelch
m
grahamb - 5/18/2026 12:14:55 PM
It is not. In SkyDemon the take-off mass is calculated as empty weight plus fuel on board (plus crew plus luggage). Analogously for the CG.
This leads to the consequences that I described earlier: You have to work-around with the empty weight or with the fuel definition, or, otherwise, if you enter the values from the aircraft weight sheet into the aircraft configuration in SkyDemon AND later enter the values from the fuel gauges into the SkyDemon route details then you will get a wrong result for the gross weight and CG.
Edited 5/18/2026 3:54:26 PM by miaelch
miaelch - 5/18/2026 3:38:31 PM
It is not. In SkyDemon the take-off mass is calculated as empty weight plus fuel on board (plus crew plus luggage). Analogously for the CG. This leads to the consequences that I described earlier (you have to work-around with the empty weight or with the fuel definition).
So you declare the empty weight and CoG to SkyDemon as including the unusable fuel. I just can't see how that is a problem.
miaelch
m
grahamb - 5/18/2026 3:50:44 PM
I just updated my previous post. Please think about it in detail. (Sorry, I don't want to be rude. But I think there is nothing more to explain.)
Declaring the empty weight and CoG in SkyDemon as including the unusable fuel is what I described as work-around No. 1 in my first post. This method makes the whole unusable fuel feature obsolete because you have to set the unusable fuel to zero.
Edited 5/18/2026 4:15:11 PM by miaelch
miaelch - 5/18/2026 3:56:46 PM
I don't need to think about it in detail, as I'm very happy that the system I use for my own aircraft is perfectly fine.
My aircraft's nominal fuel capacity is 140L, of which 4L is unusable/undrainable. The empty mass and balance of the aircraft defined in my SkyDemon profile includes the 4L, and the capacity of the tanks is set up as 136L. I'm still struggling to see how this is a problem.
Avgas fuel density can vary by up to about 6.5% according to temperature, but I've never met any GA pilot who worries about that in their W&B calcs.
miaelch
m
grahamb - 5/18/2026 4:28:01 PM
Ok, so it is exactly as I said. You don't use the unusable fuel feature.
Apart from that, the temperatute depending fuel density is not a featute of SkyDemon. So, luckily, we don't have to discuss its correctness, and it is quite useless to mention it here.
Edited 5/18/2026 4:49:37 PM by miaelch
miaelch - 5/18/2026 4:38:24 PM
I can't find such a feature in standard SkyDemon.
You could effectively create one by specifying a load point name 'Unusable Fuel' with the arm/moment the same as the fuel tanks and a default mass equal to the amount of unusable fuel, but the risk in doing that is that the official weight schedule may already include it.
Know your aircraft and its documentation and set up the SkyDemon profile accordingly. If you are using a profile that has been handed to you by a Flying School etc, and you think it's wrong, you should get them to change it. There's nothing wrong with SkyDemon in my opinion, you can configure it to do what you want.
miaelch
m
grahamb - 5/18/2026 4:55:12 PM
Sorry, but I really don't understand the whole discussion. You haven't even found the feature but you tell me that it is correct and you let me explain its problems over and over...
