IFR/VFR transition points
kholt
kholt
Posts: 20, Visits: 196
Now the new rules on Enroute IR is finally published by EASA, EIR pilots will soon need to specify VFR/IFR and IFR/VFR transition points in their flightplans. I hope Skydemon will be able to handle this in the near future.
It should be able to appoint transition points by point-and-click the same way you designate other waypoints. The app should check MSA at the transition point (1000 ft to highest terrain/obstacle within 5 NM) and also check if the cloud ceiling - based on nearest reported weather - is higher than the point MSA.
Karsten
