IFR/VFR transition points
http://forums.skydemon.aero/Topic11658.aspx
By kholt - 4/3/2014 9:03:29 PM
Hi
Now the new rules on Enroute IR is finally published by EASA, EIR pilots will soon need to specify VFR/IFR and IFR/VFR transition points in their flightplans. I hope Skydemon will be able to handle this in the near future.
It should be able to appoint transition points by point-and-click the same way you designate other waypoints. The app should check MSA at the transition point (1000 ft to highest terrain/obstacle within 5 NM) and also check if the cloud ceiling - based on nearest reported weather - is higher than the point MSA.
Karsten
By pschartau - 12/16/2014 12:07:45 PM
It would be great if SD were able to file Y, Z and I flight plans. A feature I've really been missing.
And if somehow the EuroGA AutoRouter could be integrated....... Smile
