SkyDemon Flight Planning
How to delete unwanted aircraft from Iad mini library
Mikernav
Mikernav
posted 10/19/2013 5:39:13 PM
Visits: 129
Anyone know how to delete aircraft no longer wanted in library of aircraft on I Pad version 3.0? I can do it on PC version and edit those saved on Cloud, but no obvious delete function on I Pad version.
Tags
ac library
I Pad mini
planning
Bouwair
Bouwair
posted 10/19/2013 10:27:14 PM
Visits: 2.9K
select setup then select aircraft
On the aircraft you want to delete swipe to the left. You will see a delete button.
thats all
Edited
10/19/2013 10:27:56 PM by
Bouwair
Mikernav
Mikernav
posted 10/21/2013 12:11:38 PM
Visits: 129
thanks. same advice from Hannah at SD. Had tried it, as it is the usual way on I Pad, but obviously had not swiped hard enough!
