SkyDemon Flight Planning
.flightlog to .gpx conversion
adhawkins
adhawkins
posted 10/12/2013 6:14:19 PM
HOT
Visits: 2.5K
Is there any means of doing a 'mass' conversion of .flightlog files to .gpx format? Any plans to produce one?
Failing that, any chance the format of the .flightlog file could be documented so that I could consider writing one myself?
Cheers
Andy
Threaded View
Threaded View
adhawkins
Have you had a look at the .flightplan file? It's XML and is pretty...
10/14/2013 8:09:13 AM
[quote][b]stevelup (14/10/2013)[/b][hr]Have you had a look at the...
adhawkins
10/14/2013 9:18:19 AM
Ok, done some digging. There are 6 fields per line, here's what I've...
adhawkins
10/15/2013 9:23:01 PM
Field 3 is the heading (a trip from Oaksey to Oaksey started and...
10/16/2013 8:33:09 AM
Thanks for that Steve, seems to agree with my findings from reading...
adhawkins
10/16/2013 9:09:19 AM
Ok, getting there I think. All looks good, but for some reason my...
adhawkins
10/16/2013 8:42:25 PM
Fields are: Elapsed time (milliseconds) Position Track (degrees...
10/21/2013 3:16:17 PM
Excellent Tim, thanks for confirming that. Andy
adhawkins
10/22/2013 12:33:57 PM
Returning to this after a holiday with another question. The first...
adhawkins
11/5/2013 12:43:59 PM
The filename itself should include the start time on old files....
11/5/2013 12:53:38 PM
Ok, seems like I had the right idea then. Finally, where does it get...
adhawkins
11/6/2013 12:36:01 PM
I can't remember what's in the name tag. Is it a friendly description...
11/7/2013 1:04:22 PM
It's something like 'Kemble to Cranfield'. Ok, I obviously won't be...
adhawkins
11/8/2013 12:19:01 PM
