By pink leader - 7/10/2012 5:05:19 PM
In SD desktop, if I plan a route which transects the Olympic restricted area, it seems that when you fire up the ICAO FPL window it does not show the boundary points or the time at boundary. Is this because its not yet mandatory (starts 15/7 I believe) or because the desktop verison does not support this functionality. Also I am asuming it includes the Olympic address -- correct?
Cheers
d
By Tim Dawson - 7/26/2012 12:26:48 PM
If you need to file two flightplans for two separate journeys, you'll need to define them as two separate routes in SkyDemon. When you then go to generate a flightplan for each, SkyDemon will populate it properly.
