By JRDeane - 5/22/2012 11:16:58 AM
Have set up a new generic GPS - works fine with SD Plan "stand alone". SD Plan works fine on my PC.
They connect via active sync
However when I try to "Sync" to transfer routes / logs I get a message "Operation Failed. Could not create remote file"
Can anyone advise a solution?
John
By JRDeane - 5/22/2012 7:39:54 PM
SOLVED!! Having seen comments elsewhere on solutions to other problems related to there possibly being two instances of SD running I reformatted and hence wiped clean the microsd card in my GPS, reinstalled SD mobile navigation using Active Sync as the default option . Tried to sync a route and it works fine without error messages
I have no in depth understanding of the causes just know that this fixed it! Hope this may help others who may experience a similar issue.
John
