Inconsistency in NTAM between PC / Android (2 probs)
http://forums.skydemon.aero/Topic39111.aspx
By Fred4680 - 8/15/2026 10:09:38 AM
Because of a fire in the east og Belgium DGTA create a notam this morning.
FROM: 15 AUG 2026 08:11 TILL: 16 AUG 2026 10:00 EST TEMPO SEGREGATED AREA (TSA) 'BAELEN' ESTABLISHED 503148N 0060442E RADIUS 05NM UP TO 4500FT AMSL DUE TO FOREST FIRE. ALL TFC EXCLUDED, EXC: POLICE, SAR, AMBULANCE AND FIREFIGHTING. Lower limit: GND Upper limit: 4500FT AMSL
In SD (PC) no display of this one this morning
On Android device (Samsung S24 ULTRA), the notam appears but there are diffirences between the notam text and the notam docoding ...
But perheaps it's for an easy way to dispay that coordinates are rounded and circle is greater
BUT THE BIGGEST CONCERN Is : Why does the notam doesn't appear on PC application
KR.
Fred
By Tim Dawson - 8/17/2026 9:55:53 AM
The "Horizontal" part of the What's Here menu is showing you the Q-line of the NOTAM. SkyDemon is usually able to extract more precise coordinates from the E-line and use them on the map.
