SkydemonMD on Mac
http://forums.skydemon.aero/Topic3759.aspx
By denopa - 8/6/2011 6:18:46 PM
Hi
Anyone using the device on a Mac, how did you connect it? My mac doesn't even recognise it as a mass storage device. Have installed active sync on parallel, no joy either.
By denopa - 8/11/2011 9:52:23 AM
The reason it didn't work was that USB wasn't turned on in Parallel (I had turned it off because I was tired of being asked every time if I wanted the device to connect to Windiws or Mac). To turn it on you need your virtual machine to be turned off.
Then you should install ActiveSync, and then connect your MD in ActiveSync mode.
If you want to connect to your mac you do need it in Mass storage. But I still use the desktop version as I have my aircraft configs on it, and also I'm not always connected to the Internet.
