+x+xJust manually downloaded 3 years of flights from Skydemon to create my own map. Looked desperately for a folder of log files or a way to export so I will this a +1
KimW,
Which map facility did you use for this? SD or something else?
Tony
I used
https://www.mygpsfiles.com/app/It creates every flight in different color, but I wanted a more clean look. You can play with track width, transparency and color.
If I could batch download that would be an easier workflow, but now I just exported one by one, and will do that periodically to create new maps as flights are added.
