Feature Request : Dynamic Direct to
http://forums.skydemon.aero/Topic36208.aspx
By Tim Dawson - 8/21/2023 9:53:07 AM
Ok, I understand that's a big deviation. As others have said though, the DI instrument at the bottom shows you the track to fly, and the trajectory line coming from the front of your on-screen aircraft should be a great indicator that you're on track towards anywhere.
To clarify, you'd still like an "extra" magenta line or similar from your position to the next waypoint in addition to the things mentioned above?
By jffuchs - 8/14/2023 7:04:22 PM
Hello Aviators,
I am looking for a dynamic "Direct to" with the magenta vector map that is continuously at my position. Thank you
Best regards,
Frederic
