Hi!1) As the title says, does the SD logging feature log the number of landings and take off's (T/Os)?
2) What are the criteria used for detecting landings and T/Os?
If I've read correctly it detects a T/O if the speed is above 30kts (??), but is that the only criteria? Does it differentiate between a TO and an aborted TO (eg. aborted at 50 kts)?
Thank you for your help!
